Fade Glitch in SCS9.1
Gary Matheson
Post by Gary Matheson » Tue May 09, 2006 7:37 pm
I am experiencing a problem which seems to be consistent and repeatable on different computers and wondered whether this has been noticed by other users - if not, could you look into it Mike?
The situation is when I have loaded, or programmed a show file which includes Stop cues with 'Fade out and then stop' and first run the show, it operates smoothly and without a problem. If I then reselect cue 1, or 'Go to Top' and rerun the show, all of the fades do not fade out completely, but fade down to a low level, stay there for a second or so and then stop.
The only way to cure this seems to be to close the file and re-open it, which again gives me a smooth initial operation, but subsequent runs exhibit the same problem.
Gary Matheson
Drama and Technical Theatre Applications Co-ordinator
Gary Matheson
Post by Gary Matheson » Tue May 09, 2006 8:28 pm
:oops: I've just downloaded 9.1.4 and this problem no longer exists, so either a fix has already been established, or perhaps I had a corrupt file. Thanks anyway!
Gary Matheson
jmgordon
Post by jmgordon » Tue May 09, 2006 8:35 pm
I'm not having this problem. It will probably help Mike if you confirm whether or not you have upgraded to SCS 9.1.4.
(prepared before but submitted after Gary's second post!)
Post by Mike Daniell » Tue May 09, 2006 9:10 pm
Gary, if you were previously using version 9.1.0 (the first general-release version) then a fix in 9.1.1 covers that bug. Amongst other changes, 9.1.1 fixed an error in re-running a cue with fade out, which stopped fading out about 0.5 second before the end when the cue was re-run, and then continued playing for about another 0.5 second beyond the end of the cue.
