So here's the story -- It's hypothetical at the moment, but I know it's coming up soon.
Say a show is designed in Standard -- And the machine at the venue is running Professional -- And it's decided to add some volume curves (and thank gawd for those) -- and then say it goes back to the designer running Standard again.
(A) I assume he isn't going to see those curves.
(B) Once he saves that file again, are those curves still going to show up on the Professional machine at the venue?
From Standard to Professional and back -- Anything lost?
Re: From Standard to Professional and back -- Anything lost?
Interesting. I've just run a test here and found that the Standard License user can see all the level points created by the Professional License user and can adjust them, but can only create fade-in and fade-out level points. So the constraint is currently just imposed when creating level points. I'll probably leave it like that, even though that wasn't intentional!
That's kind of a relief. I'm not sure which levels everyone involved are using at this point.
