Cues that have a Loop Cross-Fade time entered... automatically release their loop at that time and don't loop back. (See Cue 30 in the diagnostics file)
In Audio tracks, if a track has a Fade out time listed, when I hit Clear All ... it creates a full song-length level change from Max to 0. Basically it creates a full track length fade out. Am I doing something wrong?
[Fix 11.3.2] Loops releasing on their own and Clear All fade
Re: Loops releasing on their own and Clear AAll fade out
Fix ready for 11.3.2.
I have encountered a similar (but opposite) fade problem in 11.3.1, but not using Clear All. I entered by mistake the desired fade out time in the fade in box, deleted it and found I had created a full length fade in. This was quite tricky to clear, can't quite remember at the moment what I had to do .
Will the fix correct this too?
Hmm. I'd overlooked that, but the issue of clearing the fade-in or fade-out time is now also fixed for 11.3.2.
