Blank Screen
WildBunch
Blank Screen
Post by WildBunch » Wed Jun 25, 2014 11:50 am
Running Windows 8.1 on a Sager Laptop. 1080 Projector on HDMI port. SCS 11.2.6. Sound cues work well. When I add in a still image, all screen s go dark. I an alt-tab to the application, but it doesn't show. I can alt-tab to other applications. I have to kill the SCS process and start it again to see it again.
It is doing really wierd stuff to my displays.
Re: Blank Screen
Post by Mike Daniell » Wed Jun 25, 2014 10:17 pm
Very strange that all screens go dark. Could you email me a diagnostic dump file? You can create this file by starting SCS and selecting 'Create Diagnostic Dump File' from the drop-down menu displayed when you click the Help button in the main window. The file will be saved in a folder named "SCS Dumps" under "Documents" or "My Documents".
WildBunch
Re: Blank/Blank Screen
Post by WildBunch » Thu Jun 26, 2014 11:31 pm
It is going to be difficult to perform the actions requested.
The application clears all screens, and becomes invisible. Only when I press alt-f4 does it become momentarily visible before it exits. Is there a registry setting or a special build to do the log thing automatically?
Main screen is my laptop. Screen 2 is a little displayport screen. Screen 3 is a hdmi screen.
The displayport screen is one of these: http://www.adafruit.com/products/1652
When I disconnect the displayport screen, things work as expected.
Main screen is my laptop. Screen 2 is hdmi projector. This works.
Re: Blank Screen
Post by Mike Daniell » Fri Jun 27, 2014 9:17 am
The key information is how the displays are set up in Windows. With your displayport unit connected but without SCS started, right-click on your Windows desktop and select 'Screen Resolution'. What settings do you have for each display? A screenshot of this 'Screen Resolution' window would also be helpful.
