[Fix 11.3.0] problem to fade and stop go to cue (Pic)
mookai1973
Post by mookai1973 » Sun Jun 01, 2014 9:03 pm
Dear All,
1.when I play a cue and then I make a fade and stop all earlier cues (any type) all cue in sub-cue working except go to cue it's still working, How can I fix this to stop "Go to Cue"?
2.Can we linked and sync 2 video in sub-cue? (same a audio link in sub-cue) I use 2 video files in sub-cue and out to 2 LED wall screen.
I'm test with 11.2.5, 11.2.6, 11.3.0 rc4 it's same problem
Best Regards,
Kai
KAI
AV Department
Phuket Thailand
Re: problem to fade and stop go to cue (Pic)
Post by Mike Daniell » Mon Jun 02, 2014 12:02 pm
mookai1973 wrote:1.when I play a cue and then I make a fade and stop all earlier cues (any type) all cue in sub-cue working except go to cue it's still working, How can I fix this to stop "Go to Cue"?
That's a bug. I now have a fix ready for 11.3.0 rc5 which should be available this week. If you need the fix sooner then let me know and I'll retrofit it into 11.2.
mookai1973 wrote:2.Can we linked and sync 2 video in sub-cue? (same a audio link in sub-cue) I use 2 video files in sub-cue and out to 2 LED wall screen.
Video files cannot be linked as tightly as audio files as the underlying software doesn't support this. However, with a cue containing two video sub-cues and using the latest test version of 11.3, I get about 0.03 second delay between video starts (as measured in a log file). Viewing the result gave the impression of the two videos starting simultaneously.
mookai1973
Post by mookai1973 » Mon Jun 02, 2014 2:00 pm
Dear Mike,
Thank so much for fix it and I can waiting in rc5.
KAI
AV Department
Phuket Thailand
