I am evalutating your product ...
I would like to receive some hints for creating my first project
I have to create some video cues. Most of them has to be started by midi input, some others have to start automatically following earlier cues or by manual input.
Most video have to fade out using SFR (by midi input)
Which is the best way to set RUN MODE ??
help with my first project
Re: help with my first project
How many video cues will you have, and are they to be played in random order or always top-to-bottom of the cue list?
If you are playing you cues top-to-bottom of the cue list then use the default run mode of 'Linear'.
If you are playing the cues in random order then try run mode 'Linear AND Non-Linear (pre-open all non-linear cues)', although if you have a lot of video cues this could be an issue.
