[Fix 11.2.5] 11.2.4 - closing editor stops ANY playing cues
As per subject - it does not make any difference which cues (if any ) were changed, exiting the editor stops all running cues. This is a major problem when you need to tweak cues during a rehearsal! Previous versions have not done this - it was possible to edit cues and save the cue file with cues running undisturbed.
Re: 11.2.4 - closing editor stops ANY playing cues
Dave,
I've emailed you regarding this.
Trace files sent.
Dave
Trace files sent.
Dave
Based on the log files you sent, Dave, the problem is related to gapless playback. I've been able to reproduce the problem here. When the editor is closed, SCS re-assigns gapless streams but does not check if a gapless stream is currently playing. I'll work on a fix early next week.
Re: [Fix 11.2.5] 11.2.4 - closing editor stops ANY playing c
Most scenarios in which this would happen should now be fixed in 11.2.5.
Seems to be fine now. Thanks.
