SCS 11.1.4 Available
Locked
Post by Mike Daniell » Fri Nov 30, 2012 2:43 pm
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 11.1.4 from the Members' Download page.
List of Changes
  • Changes have been made to make the next manual cue more obvious. The text and background colors of the next manual cue can now be set in color schemes. The default is white text on a black background. These colors are applied to the cue itself in the main window's cue list, and to the 'Next Manual Cue' field. In the cue list and cue panels the relevant cue's 'Ready' state is now displayed as 'Next Manual', also with the new colors.
  • In the Audio Driver Options and Settings for ASIO (using BASS) the SCS ASIO Buffer Length setting has been removed as it is no longer necessary since the inclusion of the async file reading feature added in SCS 11.1.3. SCS now always uses the ASIO buffer length previously known as the 'preferred length', which is the ASIO buffer size set in your device's ASIO control panel.
  • The default Audio Driver for new productions is now ASIO (using BASS) if an ASIO device is found (except for SCS Lite users).
  • Added a Production Property to allow you to set the maximum audio level to +12dB instead of the default maximum of 0dB. This is designed for ASIO outputs and is not recommended when using DirectSound. See the Help on Production Properties - Run Time Settings for more information.
  • Implemented a 'fine tuning' facility of adjusting certain time fields by using Ctrl/Left-Arrow and Ctrl/Right-Arrow to decrease or increase times by 0.01 second. This has been implemented for the following fields in the editor for audio file cues: start at, end at, loop start, loop end.
  • The timing of the audio file graph in the editor is now more accurate.
  • Fixed a few errors.
Locked
