SCS 11 Went to add audio cue in editor.
Then changed my mind. I did not want to add cue.
Could not get out of add cue mode. Kept saying I needed to add cue.
How do I abort add cue?
Can't exit add cue
Re: Can't exit add cue
When you click on 'Add Audio File Cue', SCS 11 immediately displays a file browser dialog to enable you to select an audio file for the cue. If you change your mind and decide not to add an audio file cue, just click the Cancel button in that dialog and SCS cancels the whole 'add cue' operation.
Whilst on this subject, note that in SCS 11 you can select multiple audio files from the file browser dialog, and SCS will add an Audio File Cue for each selected audio file, creating the cues in the order in which you selected the files.
