SCS 10.7.5 now available
Post by Mike Daniell » Thu Jan 06, 2011 8:52 am
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 10.7.5 from the Members' Download page.
The following changes are included in 10.7.5:
  • Added a MIDI Capture facility to MIDI Free Format Control Send cues, which enables you to set a MIDI Message for a Control Send cue by recording the required message sent by the external equipment.
  • Added a new cue type: Run External Program for running programs like PowerPoint Viewer directly from your SCS cue list. This is currently implemented using the Note cue type.
  • In Permanent Options, changed the Audio Driver's Internal Mixer default setting to Do NOT use SCS internal mixer.
  • In Production Properties, changed the order of entries listed in the Physical Device drop-down lists to place ASIO devices last instead of first, and in the Speakers/Outputs drop-down lists to place entries like "7.1 Surround (8 Channels)" last instead of first.
  • Removed Mixer Levels from Permanent Options as the functionality is obsolete.
  • Fixed a few errors.
