Hi I have a problem with a DJ Audio 8 sound card.
I get error 339 when loading SCS with it plugged in.
Can anyone help please
DJ Audio 8
Re: DJ Audio 8
This could be caused by an incompatibility between the sound card's ASIO driver and the ASIO support in the BASS audio library used by SCS. You can check this by holding down the Right Ctrl Key while you start SCS. It MUST be the Right Ctrl Key, not the Left Ctrl Key. If this starts and runs SCS OK then you can make this change permanent by going to General Options / Permanent Options / Audio Driver and selecting Ignore ASIO.
