Hello All,when a cue is playing if I press esc I get a "bong" noise is this a windows sound that I need to disable
Kevin
Bong
Re: Bong
To check whether or not it's a Windows sound, try clicking the 'Stop All' button in SCS instead of using the Esc key. If the 'Stop All' button doesn't give the 'bong' sound but the Esc key does then it would appear to be a Windows sound.
Re: Bong
HI fincaman
The noise you discribe is a windows warning sound, if you are using the headphones output of you computor you will always hear it, the best way I have found is to go to sound in the control panel and then disable all 'windows' sounds while you use SCS. Best to use an external sound unit if you can then no windows sounds are heared.
Hope this helps
Peter Jackson
Hope this helps
Peter Jackson
Peter Jackson
http://www.jacksonmedia.co.uk
