I have just bought SCS professional, and an M audio Profire 610 and am wondering how I assign the outputs on the M audio device through SCS. Am looking ofr some help hopefully some one out there knows and can help. Sorry I posted this on the suggestion board on accident.
Max
Interface with M Audio Profie 610
Re: Interface with M Audio Profie 610
Have you looked at Production Properties in the Editor? That's where you assign the outputs you want to use for the production.
btw, I'll delete your double posting in the Feature Requests forum.
i have i guess i'm just confused on how to assign them and how i route it to the different outputs on the device. How do I know that when I assign it to FOH L or Right which output it is going to go to. And is it better to run them in mono with left and right then in stereo. During the show I have four outputs and I need to be able to get very specific where they go to and I'm wondering if there is a place I can maybe get a step by step tutorial on this or what is the best way to do it.
Max
Max
Could you tell me what you see in the drop-down lists under Physical Device?
I figured it out by reading some of the other posts in this category. Thank you for your help. This is my first time using this program and I am coming up on a very short tech period so I might be back to ask a few more questions.
runawaymartin
Hi Guys . . . I'm also having problems with a Profire 610. It's OK under XP but not with VISTA . . . . is anyone running it with VISTA? Actually having a problem running any firewire i/f with VISTA/.
Any advice appreciated . . . . Martin
