[Mod 11.10.3] Release from loop and start next cue
Gubbio67
Post by Gubbio67 » Wed Sep 13, 2023 10:53 pm
Hi Mike! For a production I need to exit a loop in a file and start next cue. If I use the SFR CUE with Release from loop the only available solution is "and then continue playback", I need instead that after that loop it launches the next manual cue (which is an other audio file and a fade out and stop of the looped tracked.
Is it possible?
thank you
Re: Release from loop and start next cue
Post by Buyaicia » Wed Sep 13, 2023 11:38 pm
You can set the next cue to be started with the start of the sfr cue.
Gubbio67
Post by Gubbio67 » Thu Sep 14, 2023 12:51 am
Yes but in this way it doesn't wait the out of loop
Post by Mike Daniell » Thu Sep 14, 2023 7:21 am
From what you've described, it seems you will never want to play past the end of the loop. If that is correct, then set the 'End At' position to the same position as the end of the loop. Your next Audio File cue can then be set to start after the end of that first Audio File cue.
Gubbio67
Post by Gubbio67 » Thu Sep 14, 2023 7:35 am
Genius!
Thank you Mike!
Preston
Post by Preston » Sat Aug 03, 2024 3:10 am
HELP MIKE!
I am trying release a looping video cue and then play the next cue seamlessly at the end of the loop.
  • a 1:00m looping "preshow" video
  • Release loop and continue playback
  • AutoStart at end of looping video.
The option in the Video Sub-Cue isn't "loop" but says "repeat" and that is checked.
The looping/repeating cue never releases and just continue to play!
What am I doing wrong?
Preston
version: 11.10.2 (x64)
Post by Mike Daniell » Sat Aug 03, 2024 9:03 am
Preston,
Please email me your cue file (the .scs11 file) and tell me which cues are involved.
PhilVale
Post by PhilVale » Thu Aug 08, 2024 8:44 pm
Could a Cue Marker work for you here?
Use it to trigger you next cue.
Post by Mike Daniell » Fri Aug 09, 2024 4:48 pm
Video/Image cues and Playlist cues both include a 'Repeat' checkbox, but this is different from the 'Loop' feature of Audio File cues, because a loop in an Audio File cue specifies a particular part of the file that is to be looped. An Audio File cue may also contain more than one loop. Video/Image cues cues may contain many videos and images, and Playlist cues are expected to contain many audio files, so these cue types have a 'Repeat' property that enables the entire cue (actually sub-cue) to be continually repeated until it is stopped.
We have now added a new feature in SCS 11.10.3, which we expect to release soon. A new action is available in SFR cues: 'Cancel Repeat'. For Playlist or Video/Image cues that have 'Repeat' selected, this SFR action will cancel the repeat so that the Playlist or Video/Image Cue will complete when it reaches the end of the current cycle.
