Control cue to set a master fader level
Gubbio67
Post by Gubbio67 » Tue May 09, 2023 6:13 am
Hi Mike!
Is it possible to implement a way to send a control cue to set the level of the master volume?
My scenario is this: I follow the voice of an actor and I control with a midi controller the total level (master level) of music that hasn't to be too loud.
The cue after I have to make a music start at maximum volume, so for me it would be better to have an automation to put the master level at maximum just before the cue start.
Is it something that you can implement?
Thank you!
Re: Control cue to set a master fader level
Post by Mike Daniell » Tue May 09, 2023 8:41 am
This is already available. Look for Master Fader under Cue Control Commands in this Help topic: Production Properties - Cue Control Devices - MIDI.
Gubbio67
Post by Gubbio67 » Tue May 09, 2023 9:36 am
I use a control change to control the master fader but I want to control precisely also through some cues. I can't send a control change with a specific value between 1 and 127 in a network cue, am I wrong?
Post by Mike Daniell » Tue May 09, 2023 11:16 am
What MIDI controller are you using?
Gubbio67
Post by Gubbio67 » Tue May 09, 2023 3:22 pm
I'm using a nanokorg and to control the master I have set a knob
Post by Mike Daniell » Tue May 09, 2023 3:41 pm
I've been working on adding support for the nanoKONTROL2 and this is almost complete. I expect to be able to let you have a pre-release later this week.
Gubbio67
Post by Gubbio67 » Tue May 09, 2023 3:56 pm
Thank you Mike
