Pause last running track
I would love a keyboard shortcuts to pause the last running not all the tracks. That was if you accidentally double hit go you don't need to stop everything you could just quickly pause the last track the play it when needed..
Re: Pause last running track
Just a comment that may help out - where you only play audio cues individually consider making the cues 'exclusive' in the Cue Properties. This prevents you accidentally starting another cue while one is playing. This feature is particularly useful when using SCS for ballet music etc, but also can be helpful in other productions. Note that you can also set the 'exclusive cue' property using Bulk Edit.
