Countdown offset
Jeroen Wuyts
Countdown offset
Post by Jeroen Wuyts » Fri Mar 09, 2012 9:35 pm
In a new production, I need to see clearly the end of a loud soundfile. Therefore I use the countdown timer.
But the end of the music is not the end of the file, there is a short reverb of 1,5s in the end!
So to be able to get the exact countdown (to run a lightcue at the right moment) i want to make an offset on the countdown (-1,5s). Would be a interesting function I guess.
Thx
Jeroen
Re: Countdown offset
Post by Mike Daniell » Sat Mar 10, 2012 12:14 pm
If you can control your lighting board by MIDI or RS232 then you could set up a Control Send cue in SCS to trigger the lighting cue 1.5 seconds before the end of your audio cue.
Jeroen Wuyts
Post by Jeroen Wuyts » Sun Mar 11, 2012 4:24 am
I know that's possible,
but I'd like to keep the two systems apart.
Anyway, the timer I'd like to use often, but usualy I end up not using it because of this difference in real cuemoment and the end of the file.
If I could give it an offset, I'd actually use it all the time.
example: The microphones should be opened 2s before the end of the music.
I know, I can just open them when the timer is at two seconds, but in this case it's a wall which falls down half a meter, so I have a few other cues to take care of at the same moment.
So there it is, I have my solutions, therefore I post it on the feature request page. It would be a nice adition to this wonderful program!
grtz
Jeroen
newlifedrama
Post by newlifedrama » Thu Apr 05, 2012 12:54 am
How about using a NOTE cue that appears 2 secs before the end of the cue?
Could you use something like that notify you? You don't get the countdown, but at least it appears.
I don't have access to SCS right now, but there also might be someway to show the countdown for this NOTE cue which you can then look at
Gary Tarolli
sound guy
New Life Fine Arts
