Auto-find start of effect
d_korman
Post by d_korman » Fri Apr 29, 2016 12:27 am
I'd like to be able to position the cursor at a given point (most often at the start) in a audio file cue, and then click a button to move the "start" point to the next position in the file where the level exceed a preset (configurable) level, e.g. -40dB. This would enable be to very quickly set the cue start point to that there is no delay at the start of the cue.
Re: Auto-find start of effect
Post by Mike Daniell » Wed May 11, 2016 3:20 pm
Sorry for the delay in replying, but this is a feature I've been considering, or more specifically an 'auto-trim' button to set the start and end times. As you suggest, a configurable level for the auto-trim would be necessary.
d_korman
Post by d_korman » Wed May 11, 2016 6:11 pm
Auto-trim would be perfect, thanks!
jmgordon
Post by jmgordon » Thu May 12, 2016 9:16 am
If SCS could find the zero crossings at the same time, that would be even more perfect! I usually use a 0.2s fade in to get a soft start without clicks, unless the music starts right at the beginning of the track and I need the attack.
d_korman
Post by d_korman » Thu May 12, 2016 4:52 pm
jmgordon wrote:If SCS could find the zero crossings at the same time, that would be even more perfect! I usually use a 0.2s fade in to get a soft start without clicks, unless the music starts right at the beginning of the track and I need the attack.
Yes, I do that too. Good idea.
