"Mute" cues
moonthink
"Mute" cues
Post by moonthink » Wed Feb 08, 2006 11:33 am
I had an idea the other night, for a new cue type - let's call it a "mute" cue. I'll try to describe it...
Let's say you have one or more sound cues/files already running. Then, at the touch of the GO button, you simultaneously "mute" or "unmute" the sounds/files you choose. The files keep running, but no sound is play if they are muted.
An example of a practical application could be changing TV or radio stations, or turning them on and off.
Post by Mike Daniell » Thu Feb 09, 2006 12:40 pm
Interesting idea that could be implemented like the suggestion here. The main difference, which could be accommodated, is whether or not the cue is paused.
moonthink
Post by moonthink » Fri Feb 10, 2006 5:45 am
Yes, both pause and mute cues could have similar uses, though different approaches. Worth considering, I think.
Chris Darby
Post by Chris Darby » Sun Feb 12, 2006 12:26 pm
Level Change cues already do what a mute cue did, and more! If you just set the fade time to 0, you get a snap out, and a snap back in again. Simply set 2 cues, one to take the volume to 0 and one to take it back up to your desired level and set them to affect the same cue.
