Change the sample rate in each audio cue
allcomp
Post by allcomp » Sun Aug 11, 2019 8:28 pm
Hi Mike
Would it be possible to create a new function, which allows you to change the sample rate in each audio cue?
When I design a show in Qlab, I use this function quite often as an effect.
Brian
PhilVale
Re: Change the sample rate in each audio cue
Post by PhilVale » Sun Nov 17, 2019 2:37 am
Is there a VST around that will give a similar effect.
I'm continuingly astounded at what VST do exist and relatively cheaply if not free as well.
