Today was my first try at triggering audio cues via "DMX In". It was easy to setup and worked (sort of) on first attempt. But I couldn’t hear the first few milliseconds of the audio cue on first playback. The remainder was heard fine. I immediately triggered the cue a second time and the full audio cue played that time (and subsequent immediate plays). Letting everything sit for a minute put things back into the same issue – first playback missed half the first work but subsequent immediate playbacks were fine. And oddly enough, everything seems to work fine if I use the Go button rather than DMX In.
Anyone have any thoughts on what I’m doing wrong? Assuming it had something to do with preloading/caching I messed with the Run Time Settings / Run Mode but none of those drop down options fixed the problem.
The show file for testing only has two cues in it – each no more than 5-10 seconds long (both .WAV format – seemingly a very light processing load). The lighting rig snaps (not fades) the designated channel from 0 to 255 for triggering and resets back to 0 in 0 seconds when I release the Flash button. The two cues are set for Manual activation with MIDI/DMX Cue of 0 in the first and 1 in the second. As far as I know the laptop has a solid state hard drive if that matters.
TIA,
Mark
Audio File Cue Triggered via “DMX In” Skips First Few Milliseconds on First Use
Re: Audio File Cue Triggered via “DMX In” Skips First Few Milliseconds on First Use
This is probably due to settings outside SCS. Try the recommendations in FAQ 11 on our FAQ page.
