Hello Mike,
I may have found a mistake.
For our shows I usually use a Primary System and a Secondary System (both V 11.10.7) as backup. From time to time I control the primary system via a stream deck connected to this PC, which controls the SCS with program change commands.
Today I noticed that all commands work perfectly, only the “STOP EVERYTHING” command is not passed on to the backup system, i.e. it just keeps running. However, if I press “ESC” on the keyboard of the primary PC, both systems stop. If I press “STOP EVERYTHING” (Program Change 1) on the stream deck, the primary SCS stops, but unfortunately the secondary SCS does not.
As I said, all other program changes (Go, Fade all, Go to top, Go back, Go to next) work.
Best regards
Heiko
Stream Deck “STOP EVERYTHING” (Prg Chg) is not passed on to secondary system
Re: Stream Deck “STOP EVERYTHING” (Prg Chg) is not passed on to secondary system
Please email us the log file from a run in which this happened. Log files are saved in a folder named "SCS Logs" under "Documents". Email the file to support@showcuesystems.com.
