[Fix 11.9.0] SCS 11.8.5 SFR cue Bug
wltheaterton
Post by wltheaterton » Sat Nov 13, 2021 2:18 am
SCS Version 1.8.5
Unfortunatley i can´t provide the Diagnostic File as we downgraded SCS earlierer today to 11.8.4.1.
The bug is most likely caused by the SFR Cue "RESUME hibernating cue (with fade in if applicable)".
Issues occured with following cue sequences:
CUE 1 music
CUE 2 "FADE OUT and then HIBERNATE"
CUE 3 "RESUME hibernating cue (with fade in if applicable)"
The "RESUME hibernating cue (with fade in if applicable)" cue starts to play the track but the fade will get stuck way ahead of it´s desired target.
All of the shows we had this issue with where build on a different PC on 11.8.4.1 and used to run fine.
We got new laptop computers, installed 11.8.5 and transferred all of the show files etc.
A downgrade to 11.8.4.1 fixed everything, all issues are gone.
If it helps, here is a short video of the bug: https://wlt.no-ip.com/nextcloud/index.p ... yHNYmpP8m9
Overall SCS 11.8.5 seems to run worse than previous versions. Fades sometimes get stuck, then jump to their target position, graphics on the screen stutter a lot.
Sometimes even SCS would freeze completely after selecting a cue.
Re: SCS 11.8.5 SFR cue Bug
Post by Mike Daniell » Sat Nov 13, 2021 9:36 am
I've emailed you details of a pre-release of the next version, which I trust will address the problems you mentioned.
