SCS Crashing on startup
PhilVale
Post by PhilVale » Tue Apr 21, 2020 12:54 am
I have a screen dump of this problem but the board doesn't seem to like either . Doc or .Docx or .PDF extensions.
I have a template with a memo cue with an auto start at load time as the first cue. If I try to load the template to edit it (Full Edit) then SCS crashes.
If you can tell me where it puts templates then I can send you the template file.
It also does it if I try and create a new production from the template too so I can't create a show and send that to you either.
Not urgent I can find a way around this until it's fixed.
Running latest version 11.8.2.2
Re: SCS Crashing on startup
Post by Mike Daniell » Tue Apr 21, 2020 7:49 am
A log file will have been created and saved in a folder named "SCS Logs" under "Documents", and the name of the file includes a time-stamp indicating when the log started. Please email me the log file from a run that crashed.
PhilVale
Post by PhilVale » Tue Apr 21, 2020 5:56 pm
I reran this morning and sent log file via email.
Phil.
