[Fix 11.6.1] Hotkey press generates audio tone
Hi I'm having problems with a hot key - when the key is pressed it operates but generates an audio tone with the press
Re: HOtkey press generates audio tone
Thanks for the log file and video you emailed me. I've replied in detail by email. Basically, the sound you are hearing is caused by your Windows Sound Scheme. We recommend you change the Sound Scheme to 'No Sounds' as you don't want any Windows sounds to be played through your theatre's sound system. Check also that the checkbox 'Play Windows Startup sound' is clear.
