[Fix 11.5.0] Thread Assertion Failed on Go To Cue+multi subs
rborsey
Post by rborsey » Mon Jun 13, 2016 10:03 pm
Hi Mike - sorry to raise this when you are beavering away on 11.5 . . . I'll d/l the latest RC later and check if it has the same problem. Doesn't sound like you will have changed the basic cue engine for the new functions . . .
I have an Intro song with a loop for saying Hi to the audience and I want it to segue directly into the 1st song (which might change for different gigs). So in my usual cue file (copy attached) I created a new main cue for the Intro song and then follow it with an autostart Go To Cue to the cue for the first song. This autostarts just before or just after the Intro cue finishes. In this way I just edit the Go To Cue for a new concert. Fine plan. Unfortunately I get :
SCS Thread Assertion failed
openMidiFile[102<2>] expectd thread #SCS_THREAD_MAIN but current thread is #SCS_THREAD_CONTROL
Cue 102 is the first song cue and the second sub-cue as usual is my lighting control midi file cue. The first sub-cue is the audio file and that has started fine. In the cue file cue 113 is the Intro song. I tried it with a simple manual start Go To Cue which you will see at the start of the cue file. This works some of the time and crashes others. I think it works the first time I open SCS and the second time it crashes - ie after a cue has run successfully.
Cheers from a cold wet and windy french summer!
Richard
full cleaned 19 avr 16.zip
zip of cue file
(29.87 KiB) Downloaded 56 times
rborsey
Re: 11.4.2.3 Thread Assertion Failed on Go To Cue + multi su
Post by rborsey » Tue Jun 14, 2016 7:28 am
Howdy again. Just tried withe the latest RC and I get the same error.
A bientôt
Richard
Ps as ever all help appreciated - got a gig Saturday . . .
Post by Mike Daniell » Tue Jun 14, 2016 1:42 pm
I can't reproduce this problem so I expect it's due to the way in which the relevant cues are triggered. I've emailed you details of a tracing version to run.
rborsey
Post by rborsey » Tue Jun 14, 2016 3:50 pm
Hi - trace version received and log file on its way to you by email.
Cheers
Richard
rborsey
Post by rborsey » Thu Jun 16, 2016 7:11 pm
A huge thank-you to Mike for a super-rapid fix in RC7!!
Cheers from football-mad France
Richard
