[Fix 11.4.2.1] midi not working for new shows 11.4.2 - x32
GKL Rijeka
Post by GKL Rijeka » Fri Jan 29, 2016 11:16 pm
Hello,
I own a SCS Professional Plus license, and after last update I cannot create new shows using MIDI remote control to start cues.
When I want to setup a new show, I setup everything properly like in every show before (x32 midi in, midi control method using note on, midi channel), but from some reason the midi does not work. Test midi does not receive messages and the remote control does not work.
When I open show saved by older SCS version, midi works again. I must point out that the mixing console is 100% setup properly, because it works with old SCS saved shows.
If I edit a show created with older version of SCS, then midi triggers are ok and I can test midi inputs using test midi input (it receives data from X32). There is a kind of a work-around, as I can edit old show, delete all cues, make new cues using new music and video files and save the show using different name, but it would be a lot easier if I could create useful show from scratch - but then I encounter a problem with midi triggering and I cannot use the X32 assign buttons to control the show. So something must be wrong in the last update in regard to device changes and cue control device section of production properties.
Please fix this or find an easier work-around this problem.
GKL Rijeka
Re: midi not working properly for new shows 11.4.2 - x32
Post by GKL Rijeka » Sat Jan 30, 2016 5:54 am
A brief update of the situation...
If I open a previously saved show and edit the remote device options, for instance I choose network control over IP or other midi card, I cannot get the midi wotking. I tried to check if the network control would work, but it also does not receive midi message from the desk. However, the desk itself receives commands over network (I use it for channel mutes send etc.)
Post by Mike Daniell » Sat Jan 30, 2016 9:47 am
Confirmed, and looking into it.
Post by Mike Daniell » Sat Jan 30, 2016 4:38 pm
I've emailed you details of a new version that should fix this bug.
GKL Rijeka
Post by GKL Rijeka » Sat Jan 30, 2016 7:17 pm
Wow! That was indeed a fast fix!
I confirm that it is working now, thank you very much!
