Hi
I do not know if this is normal or is this a bug
When I add a cue notes it is empty.
Then I added a sub memo cue and I end up with 2 cues memo.
See the attached screenshot
thanks for your help.
Added cue note
Added cue memo
CUE MEMO
Re: CUE MEMO
I'll look into this. Which version of SCS are you using?
btw, the images in your posting have been lost. Note that you should be able to uploaded images directly into your posting so they don't have to be hosted elsewhere.
Re: CUE MEMO
Hi Mike
I do not know that I could import the images directly.
I use the latest version, SCS 11.4.2 rc2
Thank you
Thank you
Re: CUE MEMO
OK, I can see now what you are doing, and SCS is handling your requests correctly. You have added a Note Cue and then a Memo Sub-Cue, and that's what is shown in the second screenshot - cue 24 contains 2 sub-cues: a Note sub-cue followed by a Memo sub-cue. I guess what you really want is a single Memo Cue, so to do that you just need to select Add Memo Cue from the Cues button in the toolbar.
hth.
hth.
