Found a strange one last night - maybe it is supposed to be like this?
Not my usual gig but I was running the music for a fashion show using SCS - simply a large cue file of audio file cues, each with a fade in and maybe a start time non-zero so the music started after an intro . . . I then have a hot key defined to fade out the current cue whilst I manually start the next cue I have chosen. So I decided mid-show to change the order of the tracks and when I tried to navigate upwards past the currently playing cue using the up Arrow SCS wouldn't let me - when I get to the playing cue it sort of rebounded and left me with the next manual cue as the one after that which was playing. Using the mouse to select a cue above the currently playing cue works just fine - sadly I was in full sunlight and kept losing the cursor . . .
Anyway maybe it is a normal feature of SCS but it would be kind of useful if you could Up Arrow past the currentlyplaying cue . . .
Cheers from a very hot and sunny France
Richard
[No bug] 11.4.0 Up arrow won't go past playing cue
Re: 11.4.0 Up arrow won't go past playing cue
I understand your request, but technically it's not a bug. The Up Arrow key is (by default) a shortcut for 'Cue List Up One Row', but if that cue is currently playing then SCS auto-navigates to the next manual cue.
