I often use the "fade out then hibernate playlist" function for pre-show and interval music so that I don't have to have multiple playlists for house music. However, I think that I have come across what seems to be a bug with the "hibernate playlists" function.
If the cue fade time is longer than the time remaining on the current track when the cue is triggered then it seems to stop the playlist at the end of the track rather than hibernating. This means that the "restart playlist" cue then fails with a "Next manual cue has nothing to do! QX acts on Q1 which has completed".
I am using version 11.2.5 of SCS Pro on a Windows 7 laptop. However, whilst I have only just noticed this issue I think it may have been there for a while since I have seen the symptoms before but never managed to reproduce the issue.
I have played about with this and it seems to be 100% repeatable on my PCs.
I can send a diagnostic file if you need.
Thanks!
Rob
[Fix 11.3.0] Fade out & hibernate playlists - fading issue
Re: Fade out & hibernate playlists - fading issue
Bug confirmed. Fix ready for next release.
Thanks Mike. Excellent service as ever!
