I'm having issues with exclusive cues - after the audio cue has completed the Go button doesn't re-activate. I have to press escape to enable the next cue.
I've recreated the bug using the default demo cue file just by enabling the "exclusive cue" option on Q1 (fanfare cue)
Have I missed something?
I'm using Professional Plus v 11.7.1.2 x64 & I'll email the diagnostic file.
Andrew
[Fix 11.7.1.3] Go button disabled after exclusive cue
Re: Go button disabled after exclusive cue
I've had another report of this error, which was due to some over-zealous optimization of processing added in SCS 11.7.1.1. I now have a fix ready and have emailed you details.
Re: [Fix 11.7.1.3] Go button disabled after exclusive cue
Hi Mike
In earlier versions of SCS,I used to be able to play an audio hot key cue (i.e. a sound effect) whilst an exclusive audio cue was playing. More recent versions don't seem to allow this ( i get the red bar at the bottom stating an exclusive cue is playing so others can't start-or words to that effect!). Would this be linked to the previous posters problem?
Thanks in advance for any help you can give
Keith
Keith
Are you sure about that, regarding hotkey cues? You can certainly force 'go' for a manual-start cue by holding down Ctrl, provided you have the option set to allow Ctrl to override exclusive cue (see Options / Shortcuts). However, this doesn't apply to hotkey cues, which is probably an oversight. I've checked back on various earlier versions including 11.6.2 and 11.5.3 and these also do not allow hotkey cues to be started when an exclusive cue is playing.ktu001 wrote:In earlier versions of SCS,I used to be able to play an audio hot key cue (i.e. a sound effect) whilst an exclusive audio cue was playing.
Hi Mike
Thank you for the reply. I first used SCS in the first half of 2013 i believe so it would have been around that time. I will try and find the earlier cue file and let you know later as this is not my SCS computer.
Maybe this might be a future selectable option to allow hotkey cues to be triggered whilst an exclusive key is playing?
Thanks for all the work you do
Keith
Keith
