Hello Mike,
this day I wanted to show someone the MIDI timecode capabilities of SCS and found, that MTC output can't be enabled, because if You check "For MTC" and apply the changes, You'll find it unchecked if You change the tabs within the device manger. This is not related to OS (happens with xp and Win7 64bit) and appears also in 11.7.1. Log and diagnostic file attached.
Best regards
Jörg
[Fix 11.7.1.1] "For MTC" state can not be saved
- scs11_log_20180717_221454.zip
- (57.8 KiB) Downloaded 50 times
- scs11diag_20180717_221600.scsz
- (11.45 KiB) Downloaded 52 times
Re: "For MTC" state can not be saved
Jörg, I've emailed you a fix for this.
