[Fix 11.9.0] Time Based Cues play in a loop in Non-Linear Mode
LONGJOIN
Post by LONGJOIN » Fri Dec 03, 2021 2:14 pm
I am using SCS 11.8.5.
I created a Time Based Cues with Audio File which 'Latest Time' is left blank. If I set Run Mode to Non-Linear Mode in Run Time Settings. The Time Based Cues will play in loop when the 'Time of Day' is reached, even after a minute.
I tried to add SFR Cue and set auto start after end of the Time Based Cues, but still can not stop it from loop.
Is it possible to play the Time Based Cues only once in Non-Linear Mode?
P.S. I can not find an option under Help to create a Diagnostic File. And I can't upload .scs11 files to forum directly because the website prompts: 'The upload was rejected because the uploaded file was identified as a possible attack vector.'
Time Based test.zip
(1002 Bytes) Downloaded 235 times
I can not find an option under Help to create a Diagnostic File.png (8.78 KiB) Viewed 3295 times
Jason
Re: Time Based Cues play in a loop in Non-Linear Mode
Post by Mike Daniell » Sat Dec 04, 2021 10:13 am
I've been able to reproduce the problem and have emailed you a link to a pre-release of SCS 11.8.6 that corrects the bug.
