SoundMan-Server in SCS 11
Major enhancements to SCS functionality and the user interface
biggazdixon
Re: SoundMan-Server in SCS 11
Post by biggazdixon » Sun Aug 07, 2011 2:46 am
I know it's been a while since this conversation started and that there are newer ones on the forum but from the discussion above am I right in thinking that the delay fade feature on the matrix will allow movement of sound in the way that LCS and Timax do?
Sorry to be so late in joining in!
Gary
barneyd
Post by barneyd » Thu Jun 20, 2019 3:33 am
I've looked on the forum and in the documentation and I think I'm missing something.
Can someone point me to the delay setting for live inputs (either devices or in live input cues) please? I am on a show being played in a railway arch to an audience outside the arch. I am going to reinforce the sound from inside the arch but want to make use of the Haas effect so the audience can't tell the sound is amplified. It calls for a simple delay on the mic inputs but I can't find the setting.
Post by Mike Daniell » Thu Jun 20, 2019 5:22 am
If you're wanting to do this with live inputs then unfortunately this feature has not been implemented in SCS. If you are using a digital mixer for your mics then you may be able to implement this effect directly in the mixer.
barneyd
Post by barneyd » Thu Jun 20, 2019 6:20 am
I was hoping to do it in Soundman. I believe the capability is built in to the server. Is there a plan to implement control of that parameter in the crosspoint? - there was a bit of a discussion about it when live inputs were first talked about.
I could hook up my delay unit but as this is an outside show, I was considering buying Soundman as a software replacement that I didn't have to carry to the site or rig up!
Post by Mike Daniell » Fri Jun 21, 2019 2:48 pm
Unfortunately there are no plans in the short term to add this functionality.
barneyd
Post by barneyd » Sat Jun 22, 2019 6:07 pm
Fortunately, I don't need to control the delay during the show, I just need it to be there. Therefore I can set the delay parameters using a simple command issued in a separate telnet interface (if I had SCS ProPlus I could issue this as a telnet control send cue at the start of the show).
This seems to work as long as I open the telnet window before I start SCS. If I open the telnet session after SCS has started, all my commands come back as invalid. When I look in the log, the text commands are all preceded by random characters. Not a big problem because it works if I open the apps in the right order.
Another alternative might be to control SM-S with Midi Show Control, which is referenced on the RSD website but I can't see any documentation on how to do that so I guess it isn't implemented.
charlier
Post by charlier » Sun Jun 23, 2019 2:16 am
Hi Barney - I will report your results regarding the telnet invalidity to the developer and find out what might be happening. SM-S doesn't accept MSC directly, only via SoundMan-Designer. Charlie
Charlie Richmond - SoundMan-Server developer
Richmond Sound Design Ltd.
charlie.rsd@gmail.com
charlier
Post by charlier » Sun Jun 23, 2019 9:58 am
Loren says: I've tried to duplicate this with two telnet sessions and can't, but then I don't have SCS installed. Maybe Mike can try it and see if he can duplicate it. If so, the log might be interesting.
Post by Mike Daniell » Sun Jun 23, 2019 4:03 pm
Barneyd, a log file will have been created and saved in a folder named "SCS Logs" under "Documents", and the name of the file includes a time-stamp indicating when the log started. Please email me the log file from a run in which the above occurred.
