supported audio devices
Hi
I am wondering if this software supports the M-Audio products I am looking at using M-Audio Fast Track Ultra 8R, However if some one can suggest something else that has 8 outputs that would be great.
Cheers
Cheers
Re: supported audio devices
Maudio Delta 1010 & Delta 1010LT (Both internal)
Gigaport HD (USB)
All work OK with SCS10
There are others but I have not used them, other members should be along shortly
Gigaport HD (USB)
Revolution 5.1
Revolution 7.1
Delta 44
Delta 66
All work fine, although the Deltas sound MUCH better than the Revs due to balanced outputs and professional output level (+4dBu vs. -10dBu for the Revs)
I also own a FastTrack Pro, but haven't used it for SCS output as yet.
Revolution 7.1
Delta 44
Delta 66
John Kowtko
Sound Designer/Engineer
Redwood City, CA USA
Thanks Guys
I think I am going to give the fastrack 8r a try, It works for what I need.
Cheers
Cheers
Seems like a nice unit.
I'm curious to know if a USB device can support the bandwdith of 8 simultaneous outs (or ins for that matter) without glitching ... please send us an update when you've worked with it. If it works well, I may want to get one!
Thanks. John
Thanks. John
John Kowtko
It should work no problem as I have no intentions of using the inputs at this point, just the outputs.
I previously used an m-audio firewire 4/10 with 8 audio channels out. Since version 10 of scs I am using an m-audio 18/14 and have 8 channels of audio from the ADAT optical out straight into my Yamaha 01V96 mixer. No wires !! Brilliant !! This also means that the channels 1-16 of the mixer are freed up for band etc. No problems at all so far.
Dik Thacker
Dik Thacker
ADAT to the 01v? That's great ...! I posted a thread on this a while ago and at the time nobody seemed to have tried it. Glad to hear you can utilize all eight channels.
John Kowtko
tested SCS 10 with following cards:
- Soundblaster PCI (one onboard, one in PCI slot)
- Echo Layla 20
- Marc Marian ADAT card into M7CL
All work fine.
Regards Jörg
- Echo Layla 20
All work fine.
Regards Jörg
Greetings,
Just thought that I'd throw my 2 cents out there. I have been using an M-Audio Transit USB and an Alesis Multimix 8 USB for about two years now, and have added an M-Audio Quattro USB about 9 months ago. All work beautifully.
Cheers,
David S Erickson
Technical Director
Northwest Classical Theatre Company
Portland, Oregon
USA
Cheers,
David S Erickson
Technical Director
Portland, Oregon
USA
Also tried a Maudio Fast track Pro (USB) from a laptop and a Roland (Cakewalk) UA101 USB from a desktop
Both work fine no problems.
Change the 'type' of this topic to 'sticky' so it stays at or near the top of this Forum. Feel free to add more supported devices.
RME Fireface UC
RME Digiface
Greetings,
Walter
RME Digiface
Greetings,
Walter
Presonus Firebox - 6 balanced outs - May have been discontinued.
Behringer UCA222 - Inexpensive 2 unbalanced outs - I carry one in my computer bag to use in a pinch for FOH music and such.
Steinberg VSL2020 16 ADAT in and out to Yamaha 02R
Sound & theater technician
Schouwburg Kortrijk
Belgium
Schouwburg Kortrijk
Belgium
