Running SCS off a different PC this time. In editor mode I cannot get the rest of the screen to appear, as it cuts off on the right and bottom sides. Reducing and enlarging the window doens't help. Worse, I am given NO to scrollbars to move up and down my cue list in editor mode, so I've only been able to program cues up to a certain point. Usually, on other pc's I've given scroll bars to move up and down my cues in editor mode (I DO have scrolls in play mode.)
Anyone have any ideas?
Scrollbars Missing? (solved)
Re: Scrollbars Missing?
Unlike the Run Screen (the main window), the Editor does not scale according to screen size, so my initial thought is that the screen size (in pixels) is too small for the Editor. The minimum screen size for SCS 9 is 1024x768 pixels. What screen size do you have? Also, what is the display DPI size? It should preferably be 'normal', which I expect is 96 DPI.
Thanks for the FAST reply. Changing the pixels did the trick! You rock!
