Strange buzz when hdmi plugged into pc
ozstar
Post by ozstar » Tue May 06, 2025 8:02 am
When I plug the hdmi cable into my laptop PC to the venue screen, the foldbak speaker has a hum.
Have changed all leads and power points but it still buzzes as soon as I plug the hdmi in.
Very weird and wondered if there was any suggestions we have not thought of.
Thought it was a earth ptoblem butnot sure how to fix it.
The speakers is fine without that cable.
oz
dee99
Re: Strange buzz when hdmi plugged into pc
Post by dee99 » Tue May 06, 2025 11:01 pm
Did you try it with the laptop running on battery only? If it is quiet on battery it could be something to do with your laptops power supply.
PhilVale
Post by PhilVale » Fri May 09, 2025 2:10 am
I get something similar (a crackling rather than a hum) with my laptop when plugged into docking station which also provided power. Works fine either not on the docking station or if not plugged in to power at all. AND it's not an SCS problem as it accects other audio as well.
ozstar
Post by ozstar » Fri May 09, 2025 10:56 am
Thanks guys.
I will try the battery power only to see if that affects it.
Also after research found a few small gizmos which may help.
Will post the results.
