Quick query on audio files in multiple cues
d_korman
Post by d_korman » Mon Sep 30, 2024 9:26 pm
If I have multiple audio file queues playing different parts of the same audio file at different times, is the file only loaded into memory once?
LONGJOIN
Re: Quick query on audio files in multiple cues
Post by LONGJOIN » Tue Oct 01, 2024 4:41 pm
Do you want to ask: If more than one cue references the same audio file, will this file be loaded only once in memory?
d_korman
Post by d_korman » Tue Oct 01, 2024 5:38 pm
Pretty much - don't know where the "queue" came from, I typed "cue"!
Let me be more specific:
I have a 1 hour audio file cue running with a loop to provide a background. Also in that same file, outside the area looped in the first cue, are a number of sections that I want to use for spot effects dropped in here and there with audio file cues as required by the script.
If I reference the same audio file in those cues as is playing in the loop, does SCS use the already loaded file (hopefully) or does it load further copies? It the latter, then I am better off extracting the spot effects into separate files.
Post by Mike Daniell » Tue Oct 01, 2024 6:17 pm
Please email us the log file from a run in which you have these cues loaded and run. We can then check the relevant function calls. Log files are created and saved in a folder named "SCS Logs" under "Documents", and the name of each file includes a time-stamp indicating when the log started. Email the file to support@showcuesystems.com.
d_korman
Post by d_korman » Tue Oct 01, 2024 6:58 pm
I will once I've programmed the show! First tech meeting this week, it'll be a few weeks after that I have a show file ready.
Dave
