SCS 11.9.3 Available
Locked
Post by Mike Daniell » Fri Jul 01, 2022 11:23 am
SCS 11.9.3 is now available on the Download page of the Member Area.
This is a bug-fix release.
Bugs Fixed
  • A memory error could occur on entering an OSC command in a Control Send cue and then clicking on another sub-cue in the editor.
  • When checking for existing devices in a device map, if a required device description was not found but a 'similar' description was found, then SCS may have used that. This was due to a now-obsolete work-around for changes to device descriptions that occurred with some device drivers and/or Windows several years ago. That SCS work-around has been removed so an exact description match is now required when SCS searches for existing devices.
  • When entering or changing a Cue number, if the entered number has already been used then an 'already exists' message will be displayed. However, under some conditions this message would repeatedly display after clicking OK. This applied particularly when entering or editing a video/image cue.
  • You could not change the Activation Method of a callable cue if another used callable cue existed.
  • If you selected 'Large' as the 'Video Monitor Size' in Options and had no secondary screens attached, then any image cues set to cross-fade would only partially fill the video monitor panel.
Although this only a bug-fix release, it does also include the latest version of LAVFilters (0.76.1). If you use or expect to use video cues in SCS then we recommend you download the version 'with LAV Filters'.
Locked
