SCS 11.9.2 Available
Locked
Post by Mike Daniell » Fri Jun 10, 2022 11:01 am
SCS 11.9.2 is now available on the Download page of the Member Area.
This is primarily a bug-fix release.
New and Changed Features in SCS 11.9.2
  • In 'Print Cue List' you may now choose 'Manual Cues Only'. This can be useful if the printed cue list is to help you run the cues for the show. (This feature was scheduled for 11.9.1 but was inadvertently omitted from that release.)
  • The 'Set Position' cue type now supports the position type 'Before End' (for time before the 'end at' position of the target cue), and also supports 'all playing audio cues' and 'all playing video/image cues'.
Bugs Fixed
  • When changing the Operational Mode from a menu item under the main window's 'View' toolbar button, any resultant change in the columns displayed in the main window's cue list were not applied for cues completed at the time of this change.
  • DMX interfaces (eg ENTTEC DMX USB PRO) with a high serial number were not recognized in earlier releases of SCS 11.9.
  • Earlier SCS 11.9 releases did not accept MIDI Cue Control of hotkey cues.
  • Earlier SCS 11.9 releases failed to process the cue Activation Method 'External Fader'.
Locked
