OSC messages to Lightfactory
Posted: Wed Mar 17, 2021 8:16 pm
by allcomp
I am trying to make a control send message via OSC to Lightfactory in free format through port 9000 and UPD as network protocol, so that I can fire a cue in Lightfactory.
I can do it in SCS when I choose LF as remote device, choose Telnet, port 3100, ASCII as entry mode and the message: CUE "Cue List 1" 1 GO
But I can´t figure out what the message has to be in free format. In the Lightfactory manual it says this:
- Skærmbillede 2021-03-17 111334.png (61.36 KiB) Viewed 3621 times
And with no examples, it´s hard for me to understand, when I am not from an English speaking country.
Re: OSC messages to Lightfactory
Posted: Thu Mar 18, 2021 6:27 pm
I've been in touch with the LightFactory developer and it appears you can supply an OSC command as just the address pattern, ie without the type tag string and arguments. An example provided was:
/LightFactory/CUE/3.4/GO
The developer also advised:
In fact any command can be sent to the system by just sending "/LightFactory/" and using the / character as a space.
e.g.
/LightFactory/1/THRU/5/@/50
This will run the command "1 THRU 5 @ 50" and set those channels to 50%.
Posted: Sat Mar 20, 2021 7:50 pm
by allcomp
Hi Mike
Well.... I already tried that type of message /LightFactory/CUE/3.4/GO, but nothing happens. LightFactory only says CUE: SUCCES. Look at these examples:
Through Telnet port 3100 - Works
- Telnet Remote.png (168.49 KiB) Viewed 3573 times
Through UDP OSC free format port 9000 CUE GO - Not working
- OSC Free format CUE GO.png (162.03 KiB) Viewed 3573 times
Through UDP OSC free format ch. 1-50 at 100 percent - works
- OSC Free format 1-50 at 100.png (163.87 KiB) Viewed 3573 times
Posted: Mon Mar 22, 2021 12:02 pm
There is an issue in the handling of OSC Free Format messages where there are no OSC arguments. To avoid this issue, set the Control Send device's 'Remote Device' to 'LightFactory', as you have done for the example shown in your first screenshot. Note that you can change the Network Protocol to UDP if you wish.
