SCS 11.6.2.1 Available
Locked
Post by Mike Daniell » Fri Oct 27, 2017 4:08 pm
Registered users with current update plans (including users who purchased or upgraded their SCS license during the last 12 months) may now download SCS 11.6.2.1 from the Download page of the Member Area. Note that as this a bug-fix release, the 'release date' has been backdated to that of 11.6.1.
You can optionally download an SCS setup file that includes the installer for LAVFilters (included with permission). If you do not already have the latest LAVFilters installed then we strongly recommend using the download with LAVFilters if you want to play any video file cues.
New and Changed Features in SCS 11.6.2.1
  • In Control Send Cues using a network device, SCS now applies a 100ms delay between sending consecutive control messages as some external equipment fails to separate the network messages if they are sent without any such inter-message delay.
Bugs Fixed
  • In Enable/Disable Cues the limit of 5 cues that may be enabled or disabled was being applied against the whole production instead of just against a single cue or sub-cue.
  • The processing of cue control messages or state changes received from RS232 and DMX interfaces has been modified to prevent potential lockups.
  • The processing of loops in Audio File Cues has been modified to prevent potential lockups.
Remote App
SCSremote is an application to remotely control SCS with an Android Smartphone or tablet. SCSremote can control basic SCS functions such as playing cues, navigating between cues, adjusting master level, and display​ing​ cue times and progress. It is available to download from Google Play. SCSremote has been developed by Simone Guisti and any queries on this should be directed to simone@rockopera.it
Some SCS features may not be available in all license levels. Please check the 'Feature Comparison' section of the Help for details.
Re: SCS 11.6.2.1 Available
Post by Mike Daniell » Sat Oct 28, 2017 9:05 pm
I should also mention that SCS 11.6.2.1 includes the latest version of LAVFilters - version 0.70.2. The version released with SCS 11.6.2 was 0.69.
Post by Mike Daniell » Mon Oct 30, 2017 12:37 pm
I've just re-uploaded the 32-bit versions of SCS 11.6.2.1 as the original '32-bit versions' were incorrectly compiled using the 64-bit compiler.
Locked
