video and 64 bits
willyBsm
video and 64 bits
Post by willyBsm » Mon Jul 04, 2016 7:35 pm
Hi
I installed the latest version SCS (x64) but alas I can not play my videos ( .avi, .mov, ...etc)
I read on the forum that it was necessary to install the codec: FFDSHOW video codec.
What I did but without success, my videos are not read.
There are there any adjustments to make in FFDSHOW? SCS?
Another question :
What happens if I install SCS (x32) or SCS Version (x64) is already present?
Both versions can coexist or it will crash?
Thank you for your help
Re: video and 64 bits
Post by Mike Daniell » Tue Jul 05, 2016 12:04 pm
I'm puzzled by this, especially as you can't even play avi files. I've emailed you details of a tracing version to run.
You should be able to have both the 32-bit and 64-bit versions installed at the same time. However, if you use shortcuts to SCS on your desktop then I suggest you manually set up a separate shortcut for whichever version does not currently have a shortcut. You could name the shortcuts something like 'SCS (32-bit)' and 'SCS (64-bit)'.
