This feature works fine, but if I use it in a hot key, it doesn't restore properly when loading a cue file. That is, the box is always unchecked after I load the cue file. I think the same thing happens for regular cues (not a hot key).
Also, my cue files are filled with ViewData / ViewCode stuff, making them quite large. Just wondering what that is
<File>
<FileName>C:\Users\Gary\Music\Celestial City\Performance\50_Thunder-Act_I_Finale.wav</FileName>
<FileModified>2007-01-16 20:30:56</FileModified>
<FileSize>18694916</FileSize>
<FileType>WAV 44100 Hz, 16 bits, stereo</FileType>
<FileTitle>50_Thunder-Act_I_Finale</FileTitle>
<FileDuration>105980</FileDuration>
<FileChannels>2</FileChannels>
<ViewData>
<ViewCode>A</ViewCode>
<ViewString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iewString>
</ViewData>
Complete any assocated auto-start cues bug (fix in 11.1.0)
newlifedrama
Gary Tarolli
sound guy
New Life Fine Arts
sound guy
New Life Fine Arts
Re: Complete any assocated auto-start cues bug
Fix ready for the next release.newlifedrama wrote:This feature works fine, but if I use it in a hot key, it doesn't restore properly when loading a cue file. That is, the box is always unchecked after I load the cue file. I think the same thing happens for regular cues (not a hot key).
The ViewString holds data for displaying the initial graph in the Editor. In the background, SCS also scans the audio file to build the maximum-zoom graph data in case you want to zoom in, but by holding the initial data in the cue file SCS can subsequently provide an 'instant' display of the initial graph for a file. Although this can make the cue file quite large, cue files are still small compared with many other file types, such as audio files.newlifedrama wrote:Also, my cue files are filled with ViewData / ViewCode stuff, making them quite large. Just wondering what that is
<File>
<ViewData>
</ViewData>
newlifedrama
Thanks Mike. Any ETA on the next release?
Gary Tarolli
sound guy
New Life Fine Arts
sound guy
New Life Fine Arts
This fix will be in SCS 11.1.0 RC2 which should be available in a day or two.
