SCS 11.0.1 Available
Locked
Post by Mike Daniell » Fri Jul 20, 2012 3:05 pm
SCS 11.0.1 is now available on the Members' Download page.
This is a bug-fix version containing the following corrections:
  • Fixed: When adding more than about 8 files to a Playlist then SCS lost the folder location.
  • Fixed: If the Editor window is maximized and then the vertical splitter is moved, the window reverted to the normal size.
  • Fixed: Skipping part of cue by clicking on the progress slider also affected the file position in a cue set to auto-start after the end of the selected cue.
  • Fixed: Cue renumbering was not refreshing the cue currently displayed in the editor.
  • Fixed: In video/image cues, there were some bugs associated with the 'Repeat' and 'Continuous' properties.
  • Fixed: If a video cue is displayed on the main window (because no secondary monitor is available) then in some environments the video cue would not be displayed.
  • Fixed: The cue navigation options 'Go to Next' and 'Go Back' were ignoring Note cues and some other cue types.
  • Fixed: The main window could lose focus for up to 5 seconds after fading out an image if that image is displayed on the primary screen, ie because no secondary monitor is connected.
  • Fixed: Clicking outside a changed text field in the Editor or Options now causes that text field to be validated. Previously that only occurred if you clicked on another field that accepts focus, or if you tabbed out of the text field.
Locked
