SCS 11 MIDI Control "Go to Next" Bug (fixed in 11.0.1)
Pochflyboy
Post by Pochflyboy » Sat Jul 14, 2012 11:17 am
Hello,
I am having a problem with the "Go to Next" and "Go Back" Commands for SCS 11. I am under a custom device controller profile that I have set up for a MIDI Note on command to control play, stop, fwd, and rev. When I hit go back or the go to next button the program goes back to the first cue or to the last cue respectively.
Thanks kindly,
Joseph Poch
Re: SCS 11 MIDI Control "Go to Next" Bug
Post by Mike Daniell » Mon Jul 16, 2012 8:21 am
Joseph,
I've run some tests here and it works OK. Can you email me your cue file (the .scs11 file)?
Post by Mike Daniell » Tue Jul 17, 2012 11:10 am
Thanks for the cue file. The problem is that SCS is ignoring Note cues (and some other cue types) when processing 'Go to Next' and 'Go Back'. In your cue file Q1, Q2 and Q3 are Note cues and Q4 is an Audio File cue. So 'Go Next' skipped down to Q4, and then 'Go Back' went back to the first cue. This isn't a MIDI-only issue - it also occurs when using the corresponding 'Navigate' options in the Main window.
Fix ready for the next release.
Eric Snodgrass
Post by Eric Snodgrass » Wed Jul 18, 2012 2:11 am
So when is the next release?
Post by Mike Daniell » Wed Jul 18, 2012 1:34 pm
Eric Snodgrass wrote:So when is the next release?
SCS 11.0.1 RC1 issued now.
