Mike
SCS 10.9.6 Playlist & level change bug
Slight bug, I’ve sent you a sample scsq file.
Q20 is a playlist with a 3 sec xfade applied to all cues
Q22 is a level change cue applying a +12db relative change to Q20 over 25 mins.
Q22 is auto started 0 secs after the beginning of Q20.
The problem is that the xfade between the playlist files does not work if Q22 is running, it does a mix instead!, if I disable or remove Q22 then the xfade works OK.
This is reproducible
10.9.6 Playlist xfade bug (fix in 10.9.7)
Re: 10.9.6 Playlist xfade bug
I've emailed you details of a version which should fix this.
Fixed in 10.9.7.
