With 10.8.5, I've copied an existing cue, pasted it in as a new cue at the end of the cue list, and then edited the details. I then created a level change cue as the next cue, to increase the level of the copied cue. This seems to work, except that the level change cue keeps changing itself to apply to the original cue, not the copy. I can change it to apply to the correct cue, and it works for a while, then I go off and do some work on other cues and when I come back to run the level change cue, it's changed back to apply to the original cue, not the copy.
Just to be clear - the level change cue is new and was created after the audio file cue was pasted and edited, it's not a copy itself.
I can't send you the cue file, as I've had to overwrite those cues and manually create the "copy" to get round this.
Tnanks,
Dave
SCS 10.8.5 - copy/paste cue problems (fix in 10.8.6)
Re: SCS 10.8.5 - copy/paste cue problems
Sounds like an internal cue pointer is not being set correctly. I'll run some tests and see if I can reproduce the error.
Fix ready for 10.8.6 and also applied to 11.0.0. An internal pointer was not being re-calculated for the pasted audio file cue. Let me know if you'd like a pre-release of 10.8.6.
Thanks Mike,
As I've re-created those cues manually now, I'll wait for the official release.
Dave
Dave
Re: SCS 10.8.5 - copy/paste cue problems (fix in 10.8.6)
Fixed in 10.8.6.
