Window 7 32bit PC
Using SCS 10.7.6 to play show cues
When selecting Stop All [ESC] either using our stop button, or the escape key we get an error
SCS Error
Error 9 Subscript out of range
SCS 10.7.6
ProcName = getAudLabel
CueFile = [Filename]
Continue with Program
if selecting yes Will get a new error dialogue
SCS Error
Error 9 Subscript out of rane
SCS 10.7.6
ProcName = stopAllEarlierCues[End]
pCuePtr=285
CueFile = [FileName]
Continue with program?
Selecting yes repeats the error for each cue. No breaks out of the dialogue.
Any help would be appreciated in resolving this error.
Stop All [Esc] Error (fix in 10.7.7)
Re: Stop All [Esc] Error
Yes, unfortunately that was a bug in 10.7.6. It is fixed in 10.8.0, but there's quite a few changes in 10.8 so if you're in production at the moment I can provide a 10.7.7 which will also fix the bug. Let me know if you need 10.7.7.
Thanks for the response, a sigh of relief that we hadn't got something configured incorrectly and it's a known issue.
The production files are complete as we have opened the show last week but put it out on tour next week.
If there are many changes, then until the kit gets back to the venue, it would probably be advantageous to stick with the interim fix on 10.7.7 Unless you believe jumping straight to 10.8 would be fine now the production files are created.
Could you provide a link for download.
Kind regards
Neil
Kind regards
Neil
I've added 10.7.7 to the Download Archive and removed 10.7.6. You will need to logon with your SCS User Name and Members' Area password to access this page.
Re: Stop All [Esc] Error (fix in 10.7.7)
Thank you Mike,
Have not long bought the curtain down on this afternoons matinee.
Had no problems installing 10.7.7 and no issues running the version.
Problem solved.
When the kit returns after the tour, we'll look forward to the upgrade to 10.8
Thank you for your assistance.
Problem solved.
