Play all cues
Peter Jackson
Play all cues
Post by Peter Jackson » Wed Feb 25, 2009 12:22 am
Hi Mike
I've only been using SCS since December 08 and I must say this is the best software I have found for running many varities of shows from Dance to Opera and two acters etc.
My question is this:
Does SCS allow you to play all cues in sequence one after another so that you can go into auditorium to listen to all cues with out having to run back and forth to the control room each time to start them?
So enabling me to check levels and make notes on each as they play through the PA.
Peter Jackson
Tech. Director
Gasleak Theatre Company
Peter Jackson
http://www.jacksonmedia.co.uk
Re: Play all cues
Post by Boswell » Wed Feb 25, 2009 1:38 am
The only way I can think of at the moment is to save your SCS file then go through and edit each cue to be auto start 0 secs after end of the previous cue.
You can put a delay in the 'Sub Cue Relative Start time' box for the first cue to give you time to get to the auditorium!
Then do a 'Save As' with a different name. then you can run it or the unmodified version as you wish.
There is no global command to run all cues sequentially as far as I know
HTH
jmgordon
Re: Play all cues
Post by jmgordon » Wed Feb 25, 2009 1:44 am
Or use a wireless mouse/presenter to control the computer from the auditorium if the signal is strong enough and the path isn't too long.
Peter Jackson
Re: Play all cues
Post by Peter Jackson » Wed Feb 25, 2009 6:44 pm
HI Boswell/Malcolm
Thanks for your replies, making up a second version with auto start times is good but I feel a bit long winded but would be an answer thank you Boswell.
Malcolm, Great Idea do not know why I never thought of it myself am for ever setting up power points and using remote mouse just need to configure to fire on mouse click
Peter
Peter Jackson
Peter Jackson
Re: Play all cues
Post by Peter Jackson » Wed Feb 25, 2009 9:12 pm
Hi Again Boswell / Malcolm
Just to let you know remote mouse is A1, just place the mouse over the go button and GO! so simple when you think about it.
I was even able to go right down onto stage to check back stage monitors as well.
Many thanks to you both for your responses.
Peter Jackson
Tech. Director
Peter Jackson
jmgordon
Re: Play all cues
Post by jmgordon » Thu Feb 26, 2009 3:37 am
Glad to be of help.
Re: Play all cues
Post by Mike Daniell » Thu Feb 26, 2009 7:42 am
Peter Jackson wrote:Just to let you know remote mouse is A1, just place the mouse over the go button and GO!
The remote mouse certainly is a good solution, and you can take advantage of both the left and right mouse buttons provided you haven't disabled right-click activating the 'Go' button (see Permanent Options / Key Mapping). Place the mouse over the Stop All button and then you can use left-click to activate the Stop All button and right-click to activate the Go button. It's useful to be able to Stop All if a cue is playing far too loud.
Peter Jackson
Re: Play all cues
Post by Peter Jackson » Fri Feb 27, 2009 1:11 am
HI Mike
Thanks for your solutions they work great, I have a remote mouse which also has page up & down buttons so am also able to map into Master volumes as well. Brilliant this programme just becomes better and better. Wish I had discovered you earlier.
Peter Jackson
